Alle Infos zum STORJ-Projekt, möglicher Ausstieg und Hardware zu guten Preisen
…rather than waiting for a payment that doesn’t arrive…
I prefer to postpone the payment for a few months or split the overdue payment into future installments.
What do you think about An empirical latency-based geoseparation idea?
Can storj just make trace road to node? or node will trace road satellite and report it. then satellite will divide nodes to regions and not send there pieces of 1 file.
Why are you so sure that in a few months there will still be a company left to pay you? I think the chances of that are below 50%. So no thank you, I prefer to get paid now. I don’t believe in future promises.
I believe I made a suggestion to replace the /24 rule with a piece-per-AS rule instead. (AS as in BGP AS Number). It would improve the situation at hand.
I dont think home users have it
Do you mean something like this?
  • AS INFONET ([AS8728] it is provider number, this mean that whole provider will be as one node
For some reason I like that idea… :smiling_face_with_sunglasses:
Did I miss the moment when the competition for the stupidest idea started again?
I also suggested that back in Aug. 2023 :slight_smile:
Th3Van.dk
AS49975
I want to get paid on the 5th.
The reality is that I haven’t been paid.
I’ve resigned myself to not expecting that money.
The situation regarding the GE payout—which would be a way to get some cash—isn’t clear.
But on the other hand, I’ve already recouped my initial investment, so I don’t mind waiting a couple of months, just in case the project doesn’t go under completely.
I don’t want to contribute to its further collapse.
I enjoy generating cryptocurrency every month.
Let’s be sensible… if you want to blow the whole thing up, just tell me the day and time.
But for now, let’s try not to sink the ship.
Please look at today’s posts in this topic:
I think there is still hope we will receive payment for July next week.
We are preparing a server for it, it should be ready soon.
Sure. Onboard customers at last. That is probably all most SNOs would ask Storj to do.
If we think about it carefully, we will get situation when distribution of one piece will start to be realy in all over the world, as 1 ISP will have only one piece of each segment, this will mean that nearby nodes cant get most pieces, also geo featuring start working.
Beautiful :slight_smile:
It is the same for me and my roughly 90 nodes.
There are some caveats though. Some ASes are really really huge with millions of subscribers. Just limiting to one piece per AS won’t really work well, but it could be used to kind of smooth things out a little. Perhaps a limit can be 4-8 pieces or something like that.
That is, run the node selection process as normal. In the end, check (in some very efficient way) that not too many pieces are in the same AS, which should be very unlikely. If they are, just run the selection process again. It would guard against people like Th3Van or myself having too much power :sweat_smile:
It would also be possible to have a worker process check this periodically. If such a case is found, it can be scheduled for an early repair instead.
I understand this is the wrong thread for this and perhaps it is not reasonable to implement this at this time, but maybe in the future.
Until then I will just apply for like 100 32-bit AS-numbers and append those to my announcements based on what /24 they are in…
Okay, we get it, you’re proposing a mega-complicated-stupid accounting system that won’t benefit anyone but you.
why do you think so, all will be in same boat.
I’m not convinced to use ASN instead of /24, as correctly stated by @peter_linder
Many new ASs are registered as with a single /24 block, so it may either not help or make it more complicated.
I believe that without economic levers, the traditional distribution of pieces using a purely technical approach will be less effective. There will always be circumstances under which bypassing a technical filter becomes cheaper, or that filter must become dynamic, or even controlled by artificial intelligence.
For example, the filter’s rigidity increases at a certain data ratio on a /24 network, forcing it to select nodes from other, more “empty” ones.
Hier mal ein Update zum STORJ-Projekt:
  1. Das Problem mit dem Online-Wert scheint endlich gelöst. Die Knoten sind auf ~96% Onlinezeit gefallen und haben jetzt “gedreht” und steigen weiter an. Endlich.
  2. Leider gibts keine Neuigkeiten zur Juli-Auszahlung und zur GE-Auszahlung.
  3. Aktuell läuft ein großer Upload auf einigen Knoten. Es ist der übliche Upload, kein Repair.
    Musste sogar einen Rechner umziehen, es hat den ganzen Upload der Gf-Leitung vereinnahmt.
    Here an Update to the STORJ-Project:
  4. The Problem with the Online-Score seems to be finally fixed. The nodes dropped to ~96% Onlinetime then made a “turn” and continue to rise. Finally.
  5. Unfortunately there is no news regarding the July-Payout and the GE-Payout.
  6. Currently there is a great upload traffic on some of the nodes. It’s the regular upload, not repair. Had to reassign one PC, it consumed the entire upload of the fiber-connection.
