I don’t think your average hard drive failure cares about held amounts.
Offline nodes also count against this. So does data rot on nodes. ISP outages which can cause multiple nodes to go offline. Uncertain geographical areas that might disappear suddenly, etc etc. With so much to protect against and a razor thin margin of nodes you could lose (I didn’t calculate it, but I’m guessing with a 1.2 expansion factor the actual percentage you could safely lose is in the very low single digits), 1.2 is just obviously impossible.
This does not seem to be a response to the line you quoted from me. But I agree, held amounts need to be higher and need to be related to amount stored.
What do you mean?
Can’t blame you for saying escrow. Storj used to use that term themselves before their legal team told them to change it because of the legal implications. And they were definitely native speakers. ![]()
How so? Losing half your held amount and having no way to ever get it back provides no incentive to do better with your node at all.
In fact, being able to get the whole amount back provides a much larger incentive to run graceful exit and actually helps encourage better behavior.
