I will deeply appreciate any help you can give me, because i am not an advanced user but I like the concept of stoj storage and i would like to use it as my backup solution *apx 4TB of data.
I cannot bother all the time the support. So I open a thread here. I deleted my previously access grants during my testing, so I left with 2 buckets and 23GB of not accessible data. I want to delete all the buckets and files, and start over. The easiest solution would be to make a new project, but i will have to request a limit increase again.
Support gave me this
Hello Vgkumpour,
Thank you for contacting Storj.
The force deletion from the browser of non-empty buckets is not possible at the moment.
The usual way is
Then you can list buckets:
uplink ls
And forcible delete the bucket even without correct encryption phrase:
uplink rb --force sj://bucket-to-delete
but everytime i am trying to use ./uplink.exe import accessgrant.txt command i get an error uplink default access already exists.
probably because of my previous attempts. How to continue?
I am trying to delete all the buckets and files *due to lost passphrase and start again from the very beggining. any help much appreciated, sorry for my very bad english.
