Ap1.gateway.storjshare.io is down
Hello @ipluggg ,
We are sorry that you have problems with our service! Our engineers are working on a fix.
You can use uplink or FileZilla to access your objects and buckets.
Facing critical issue while creating bucket. The error to the same is attached below
Hello @singlautsav ,
@ipluggg and @singlautsav - the problem should be resolved now, could you please check?
You always can check the status there: https://status.storj.io/
Its solved thank you! and thank you for status link.
