Are ther internal plans when Tardigrade works with Duplicati?
You can use S3 gateway to connect the two, it works for me.
You need to set option: s3-ext-forcepathstyle=true
It does not work.
Here is my config
“C:\Program Files\Duplicati 2\Duplicati.CommandLine.exe” backup “s3://win1test?s3-server-name=192.168.0.4:7777&s3-client=aws&auth-username=2jJR7FZB1GDgBn2PGc9qjNnthNjb&s3-ext-forcepathstyle=true” “C:\tmp\test.txt” “C:\tmp\sicherungstestdatei.txt” --backup-name=Test1 --dbpath=“C:\Users\JensAmberg\AppData\Local\Duplicati\GZIXKZYAVF.sqlite” --encryption-module= --compression-module=zip --dblock-size=50mb --no-encryption=true --disable-module=console-password-input
Can anyone confirm Duplicati is working well with Tardigrade (with S3 Gateway and forcepathstyle option activated)?
@jeremyfritzenworks perfect with latest Docker Image of the gateway also without forcepathstyle
Is it better to use the docker image for the gateway?
The Tardigrade official documentation doesn’t talk about the docker image
@jeremyfritzen For my use case it is better. I also found it only by accident. There is no documentation
I saw your other discussions.
Actually, it’s also easier for me to use an image (easier and faster to be installed and to be managed)
