I just got a couple of these errors in my logs from different nodes on the same server, should i be worried? Suspension score dropped to 98 - 95 and 92%
Any failed audit should concern you.
in this case, please, sync clocks on your host with storagenode.
If you use a VM, make sure that you have an integration service installed. Then sync clocks between host and VM.
Stop and remove the container, then run it again (docker) or restart the storagenode service (binary, i.e. Windows GUI).
You should use either NTP inside a guest OS and sync it or use integration service from the hypervisor and sync clocks on the host.
The TZ of the host doesn’t matter unless there is a bug in hypervisor code or in the integration services of that hypervisor.
