Goodmorning everyone,
I have a question, but does the AUDIT percentage reset after a certain period or not?
For example is it reset once a month like uptime?
Thanks
Best Regards
Alexey
October 5, 2020, 7:45am
2
Hello @Tony_boy_32 ,
No, it’s not. It consist of two coefficients which affect your percentage depending on how much failed audits your node have in a certain amount of time since the last audit.
If your node started to fail audits, it will be disqualified very fast.
The audit score can recover during the time of successful audits though.
You can read more there:
# Reputation and Node Selection
## Abstract
Node selection is the process wherein the set of all possible storage nodes is reduced by the satellite for uploading segments. Node selection applies to new file uploads via an uplink, as well as repair traffic from a satellite. The node selection processes endeavors to fairly distribute upload traffic among storage nodes. Node selection takes into consideration how new a node is, the overall performance characteristic of a storage node as characterized by its reputation score, and the IP address of each node.
## Background
The white paper section 4.15 describes a 'preferences' system used in node selection, based on reputation:
> After disqualified storage nodes have been filtered out, remaining statistics collected during audits will be used to establish a preference for better storage nodes during uploads. These statistics include performance characteristics such as throughput and latency, history of reliability and uptime, geographic location, and other desirable qualities. They will be combined into a load-balancing selection process, such that all uploads are sent to qualified nodes, with a higher likelihood of uploads to preferred nodes, but with a non-zero chance for any qualified node. Initially, we’ll be load balancing with these preferences via a randomized scheme, such as the Power of Two Choices, which selects two options entirely at random and then chooses the more qualified between those two.
> On the Storj network, preferential storage node reputation is only used to select where new data will be stored, both during repair and during the upload of new files, unlike disqualifying events. If a storage node’s preferential reputation decreases, its file pieces will not be moved or repaired to other nodes.
The existing reputation-like system uses uptime and audit responses. It does not currently consider geographic location, throughput, or latency. In addition to factors which affect reputation, there are other factors in node selection. These considerations currently include IP address, advertised available bandwidth, advertised available disk space, software version compatibility, and whether the node appeared to be online in the latest communication with the satellite.
One final factor involved in node selection is node 'vetting.' During upload
## Design
This file has been truncated. show original
