Audit Score
Hi Alexey,
I’m running Storj-node on my Truenas system for 3 months now.
Today i open my dashboard and see audit score in eu1.storj.io satellite.
I do a little google and found this script (GitHub - ReneSmeekes/storj_success_rate) and here is the result
storj 1 script
It seem like my node fail 1 audit, after investigate my network and my storj docker, i found that it my fault to set auto restart timer for my router.
So my question is does my node audit recover? or it just stay 99.14% on eu1 sattlite.
Many Thanks
Hello @baont,
The audit score can be affected only when your node is online, responds on audit requests but either did not provide a required piece for audit or provided a corrupted one.
Since the script detected the audit failure error, you may check - what kind of error:
If the error is “file not found”, then your node is lost that piece, this is unrecoverable. If it were a temporary issue (like disconnected disk or wrong file permissions), then it may pass the audit of this piece next time.
The audit score can recover during the time, if your do not have any other pieces corrupted/missed, otherwise your node will be disqualified if it would lost 5% of data.
Hi
An update from my situation, yesterday i receive 2 more fail audit, here are some of my logs
2022-10-21T12:25:29.029+0700    ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "3Q7P5Y6BQHR4C3ZCG327CCI7BUF2T4C24RNZUTAXTMCZQHWYGBSA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:554\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2022-10-22T13:06:01.859+0700    ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "CXZPP3HJ7NH3UIH2UMT37CZBQPH5CWS75HJAXVHXFBFY76JIU4DA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:554\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2022-10-22T13:34:35.440+0700    ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "74MWNAVUNGIM7P5MRYA5DBM37KVIX6AW46ZCEVPXURRJ32L627TA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:554\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
I’m running Storj-node container on a Truenas Scale system, I alocate 4.5Tb for storj and my system has 32gb of Ram, HDD i’m using is Exos 7E8 they use magnetic recording (CMR ) technology so theory it should have optimal performance.
I check the status of my zpool and here is result
root@truenas[~]# zpool status -v
  pool: Databoiz
 state: ONLINE
  scan: resilvered 9.19M in 00:00:03 with 0 errors on Sat Sep 24 03:10:22 2022
config:
        NAME                                      STATE     READ WRITE CKSUM
        Databoiz                                  ONLINE       0     0     0
          raidz1-0                                ONLINE       0     0     0
            03b1e2f3-96ec-4a7a-ad93-0a7b828e30ae  ONLINE       0     0     0
            3cbb10a6-fcc2-41d5-a2f6-272c2752ce13  ONLINE       0     0     0
            35ecdbce-1a3e-4716-837d-9949017a5429  ONLINE       0     0     0
            279a64ae-f165-4ecd-8ced-cea9cb35c155  ONLINE       0     0     0
        cache
          efb9e5f6-ff0b-4d73-942f-36fa5fa21d5b    ONLINE       0     0     0
errors: No known data errors
Currently i’m runing a scrub task to check my pool integrity i will update late.
And i found 2 of this command to cut down when i googleing :v
zfs set xattr=off poolname
zfs set atime=off poolname
@Alexey can you suggest for me what should I do next ?
Grep your log files for this string to see the full history of this piece. Maybe it’s the same issue as described here.
On the other hand, your audit score did drop… so maybe it’s a combination of two. grep for each piece that got logged with audit failure.
Here is my logs about that piece.
2022-10-21T12:25:29.024+0700    INFO    piecestore      download started        {"Process": "storagenode", "Piece ID": "3Q7P5Y6BQHR4C3ZCG327CCI7BUF2T4C24RNZUTAXTMCZQHWYGBSA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT"}
It seem like when my node start download and auditing that peice at the same time :v
Also today disqualify % of my node is droping, yesterday it was 2.02%
Things Are Strange, Right?
Do you not have older log entries for that piece? Without history it’s hard to say what happened.
The download you’re seeing is actually the download for the audit itself. GET_AUDIT
Also make sure you use the latest version of the earnings calculator. The audit threshold has changed, which is only reflected in the latest version.
One thing I’ve noticed in the past is that during periods of instability of my ISP connection, where the connectivity is going up and down (i.e. only about 50% of successful pings in a ping test), then it’s possible for a node to receive the audit request during an “up” period, but then if the node goes to send the data during a “down” period, it can result in failing the audit. So generally, if I notice that my ISP connection has gone into a situation like that, I’ll shutdown my nodes until the connection is fully re-established to avoid impacting my audit score.
Not sure what kind of networking gear you have, but if there’s a way to detect ISP connection instability, then that could be something to look at for investigating your current situation, but at the same time something to consider in the future.
I’m using this command to check my storj-node container logs:
docker logs 621b79f2aad1 |  grep 3Q7P5Y6BQHR4C3ZCG327CCI7BUF2T4C24RNZUTAXTMCZQHWYGBSA
And only 2 line showup like my post:
Yes, I’m using latest version of the earnings calculator, and my disqualify % still droping now it 1.84%
I will moritor status of my node and update later.
Many thanks :revolving_hearts:
Unstable connection doesn’t remove pieces from the disk:
