Audits stuck at 0
I ran the first script from Script for Audits stat by satellites and got
"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW"
  "totalCount": 0,
  "successCount": 0,
  "alpha": 1,
  "beta": 0,
  "score": 1
"121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"
  "totalCount": 0,
  "successCount": 0,
  "alpha": 1,
  "beta": 0,
  "score": 1
"12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"
  "totalCount": 0,
  "successCount": 0,
  "alpha": 1,
  "beta": 0,
  "score": 1
"12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"
  "totalCount": 0,
  "successCount": 0,
  "alpha": 1,
  "beta": 0,
  "score": 1
My node has around 10 GB egress and ingress, and has been up for around 24 hours. Is it normal to have 0 audits for each? How often are audits sent? I would expect around 3 from each satellite a day if vetting takes 100 audits from each satellite and takes around a month. Why am I not receiving any audits?
It takes time to get audits over time If you only been running for 24 hours dont expect to get 100 audits in one day normally takes a month or more to get 100+ and audits are random and knowing that your a new node you probably wont get many in the first day or at all.
Deathlessdd is correct.
However, if you run your node on linux, make sure you run the script with sudo
Thanks, I’m starting to get audits after a few days
