Autenthication failed when configuring Synology Hyper Backup
Hi.
I am trying Storj as a possible replacement for my Synology C2. I have more than 2TB but don’t want to upgrade to 5TB. So voilà…
I did configure Hyper Backup as explained in the post found on this blog
But it ends with an error message “Authentication failed. Please Check your authentication credentials”.
I did recreate my access key several times, paying attention that I grant all accesses. And IMO, the access key works at least to “List” (but I did check Read Write and Delete as well): Indeed, in the Wizard of Hyper Backup; I can see the Bucket “synology” I have created on StorJ
I don’t see any message in NAS’ Logs (Except I see that the task was created and then immediatly deleted). I am a bit lost on what to do…
Is there anyone here who experienced the same here and can, give me guidance ?
It would be much appreciated :slight_smile:
Thx in adV.
V.
Ho, what’s really weird is that I was able to create a task in “Cloud Sync”, that is working fine, with the very same info ?!?!?
So, it’s related to “Hyper Cloud” and not to my Access Key, Secret Key or my Bucket… (I use the same Bucket here)…
V.
It seems I found the root cause of my issue: an Hyper Backup task was running with my “Synology C2”. I did cancel it and next, I was able to create successfully the task with StorJ… Does not make sens (and I have lost hours of backup onto my C2), but voilà…
