Auth issue, RPC timeout
Error: rpc: tcp connector failed: rpc: dial tcp 35.224.44.57:8888: connect: connection timed out
I have tried to authorize the identity - everything is working.
Please check your network and make sure that nothing blocked in outgoing connections, you may block incoming connections though.
If you use a VPN, try to disable it. If you use a firewall - allow any outgoing connections from/to any port and destination.
