I tried signing up as a SNO with 4 different browsers without any ad blockers. Is there a way to check if the waiting list is so long or if there is a different problem with email?
Hi, there is no wait, your token should arrive in minutes. Try using android if you have it. It always works for me (tested just now)
Thank you very much for the quick answer! Helps really a lot.
No problem, just happened to be signing up a new node at that moment.
