jetzt laufen nach dem reboot komischerweiße beide docker, auch nach mehrmaligen überprüfen.
also storjlabs/watchtower und storjlabs/storagenode:last.
die logs nach reboot und nach dem stoppen mit sudo docker stop -t 300 storagenode sind folgende:
2022-10-19T19:38:29.434Z INFO piecestore upload started {"Process": "storagenode", "Piece ID": "FYHPV5A6B7S2YO5TMJG6PVJWXGFAM3ZPV776V4WZYK4OFLFAISTQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 5982264233088}
2022-10-19T19:38:29.933Z INFO piecestore uploaded {"Process": "storagenode", "Piece ID": "FYHPV5A6B7S2YO5TMJG6PVJWXGFAM3ZPV776V4WZYK4OFLFAISTQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 181504}
2022-10-19T19:38:33.686Z INFO piecestore upload started {"Process": "storagenode", "Piece ID": "EZLRXDUYSIW2O557FZ5XN5DOONK2MR3UQBPBARUJEZEGSE6NQOEQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 5982264051072}
2022-10-19T19:38:34.049Z INFO piecestore upload started {"Process": "storagenode", "Piece ID": "XDKQZL5FOG5IYCEHR2A6VF3HO3EIEAJ7YCFK7AVQMPJV4EM645JQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Available Space": 5982264051072}
2022-10-19T19:38:34.068Z INFO piecestore uploaded {"Process": "storagenode", "Piece ID": "XDKQZL5FOG5IYCEHR2A6VF3HO3EIEAJ7YCFK7AVQMPJV4EM645JQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Size": 2304}
2022-10-19T19:38:34.249Z INFO piecestore uploaded {"Process": "storagenode", "Piece ID": "EZLRXDUYSIW2O557FZ5XN5DOONK2MR3UQBPBARUJEZEGSE6NQOEQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 290304}
2022-10-19T19:38:34.615Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "KKWTWY4FGAM2BZP2U2DPIHCMIROLVQ7RMK3R3OVVNNZ3FF6SWUCQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET"}
2022-10-19T19:38:35.013Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "KKWTWY4FGAM2BZP2U2DPIHCMIROLVQ7RMK3R3OVVNNZ3FF6SWUCQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET"}
2022-10-19T19:38:35.382Z INFO piecestore upload started {"Process": "storagenode", "Piece ID": "MR7WSI4G3LOXMD4A27ABOWNXW4PDOLLC4DG5HO4L7Z7NRSRXV33A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Available Space": 5982263757440}
2022-10-19T19:38:35.405Z INFO piecestore uploaded {"Process": "storagenode", "Piece ID": "MR7WSI4G3LOXMD4A27ABOWNXW4PDOLLC4DG5HO4L7Z7NRSRXV33A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Size": 2816}
2022-10-19T19:38:42.026Z INFO piecestore upload started {"Process": "storagenode", "Piece ID": "KCX2WP6UTNZWNT3QWYLYY527BTUF2SVV3ENXVF5SIYLFBPXFCD5Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 5982263754112}
2022-10-19T19:38:42.664Z INFO piecestore uploaded {"Process": "storagenode", "Piece ID": "KCX2WP6UTNZWNT3QWYLYY527BTUF2SVV3ENXVF5SIYLFBPXFCD5Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 290304}
2022-10-19T19:38:49.568Z INFO piecedeleter delete piece sent to trash {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "YF4E3Q3OFL2VMTN4AHQTF2AZVJQ3JUPTUR3RG6EUZR6BXPANNYIA"}
2022-10-19 19:38:56,510 WARN received SIGTERM indicating exit request
2022-10-19 19:38:56,511 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2022-10-19T19:38:56.511Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2022-10-19 19:38:56,517 INFO stopped: storagenode-updater (exit status 0)
2022-10-19T19:38:56.519Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode"}
2022-10-19 19:38:56,664 INFO stopped: storagenode (exit status 0)
2022-10-19 19:38:56,667 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
mit journalctl --no-pager --since -1h | grep "dockerd" | grep -i "error" | tail
bekomme ich folgenden log
Okt 19 21:27:20 raspberrypi dockerd[631]: time="2022-10-19T21:27:20.254712560+02 :00" level=info msg="stopping event stream following graceful shutdown" error="< nil>" module=libcontainerd namespace=moby
Okt 19 21:28:01 raspberrypi dockerd[628]: time="2022-10-19T21:28:01.964473790+02 :00" level=warning msg="Failed to allocate and map port 14002-14002: Error start ing userland proxy: listen tcp4 192.168.178.100:14002: bind: cannot assign reque sted address"
Okt 19 21:28:02 raspberrypi dockerd[628]: time="2022-10-19T21:28:02.997933308+02 :00" level=error msg="36d95c52dda2a2dba610b2cd24e792f377e249cbb45da1896843faf198 6b05ba cleanup: failed to delete container from containerd: no such container"
Okt 19 21:28:03 raspberrypi dockerd[628]: time="2022-10-19T21:28:02.998058494+02 :00" level=error msg="failed to start container" container=36d95c52dda2a2dba610b 2cd24e792f377e249cbb45da1896843faf1986b05ba error="driver failed programming ext ernal connectivity on endpoint storagenode (4ac858adbe290ce2a295ce872ab7d561ff66 986ee16174f16edbe6a3ae96cef0): Error starting userland proxy: listen tcp4 192.16 8.178.100:14002: bind: cannot assign requested address"
Okt 19 21:38:58 raspberrypi dockerd[628]: time="2022-10-19T21:38:58.077739692+02 :00" level=info msg="stopping event stream following graceful shutdown" error="< nil>" module=libcontainerd namespace=moby
Okt 19 21:38:58 raspberrypi dockerd[628]: time="2022-10-19T21:38:58.078470702+02 :00" level=info msg="stopping event stream following graceful shutdown" error="c ontext canceled" module=libcontainerd namespace=plugins.moby
Okt 19 21:39:39 raspberrypi dockerd[646]: time="2022-10-19T21:39:39.272564883+02 :00" level=warning msg="Failed to allocate and map port 14002-14002: Error start ing userland proxy: listen tcp4 192.168.178.100:14002: bind: cannot assign reque sted address"
Okt 19 21:39:40 raspberrypi dockerd[646]: time="2022-10-19T21:39:40.212041401+02 :00" level=error msg="68a77c1790b3217aed0903566ae97607ea4d8eba16d4325972477dc8ad 61c3c9 cleanup: failed to delete container from containerd: no such container"
Okt 19 21:39:40 raspberrypi dockerd[646]: time="2022-10-19T21:39:40.212183993+02 :00" level=error msg="failed to start container" container=68a77c1790b3217aed090 3566ae97607ea4d8eba16d4325972477dc8ad61c3c9 error="driver failed programming ext ernal connectivity on endpoint storagenode (752d27e20ead06e36798d937f9345e885e26 dcb43b532d0d7ff865ad771f2be7): Error starting userland proxy: listen tcp4 192.16 8.178.100:14002: bind: cannot assign requested address"
