The docker runs succesfully and when i open the dashboard:
Available Used Egress Ingress
Bandwidth N/A 0 B 0 B 0 B (since Apr 1)
Disk 3.59 TB 0 B
I really dont know what this has to do with. I actually have generated an indentity and completed most of steps like a month ago, but now i try to start the node and i cant. I saw that this is may caused by port forwarding but my router doesnt give those options and just give me LAN and WAN hosts and ports. In the WAN hosts i let it empty so anyone can access it, and in the LAN i am setting port 28967 as said in tutorial. Also i cannot open the dashboard from another device with my domain name or even the local ip address. Even the request from my own computer to 127.0.0.1:14002 is just empty page but has the storj image in it…
I really dont know what is going on plz help
Please, use this checklist for offline troubleshooting:
If your node is online (I cannot see that from your excerpt), but only problem that there is no usage - then you need to check your logs: How do I check my logs? - Storj Docs
To be able to access your web dashboard you either need to use a remote access: How to remote access the web dashboard - Storj Docs or remove 127.0.0.1 from the -p 127.0.0.1:28967:28967 to make it -p 28967:28967 in the docker run command.
Hello,
I checked my port 3 days ago and it was open now it is not, i don’t know why. Port forwarding in my router is setup correctly as it was before but now i try it and shown as closed (i also contact internet service provider)
my logs looks like this :
021-05-03T17:26:07.236Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 1, "error": "ping satellite error: rpc: dial tcp: operation was canceled", "errorVerbose": "ping satellite error: rpc: dial tcp: operation was canceled\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:107\n\tstorj.io/common/rpc.TCPConnector.DialContext:71\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:186\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:107\n\tstorj.io/common/rpc/rpcpool.(*Pool).get:90\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:110\n\tstorj.io/common/rpc.Dialer.dialPool:152\n\tstorj.io/common/rpc.Dialer.DialNodeURL:106\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-05-03T17:26:07.237Z INFO contact:service context cancelled {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo"}
2021-05-03T17:26:07.238Z INFO contact:service context cancelled {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2021-05-03T17:26:07.238Z INFO contact:service context cancelled {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
2021-05-03T17:26:07.237Z INFO contact:service context cancelled {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Error: piecestore monitor: error verifying location and/or readability of storage directory: node ID in file (12iRinvMpXWBjCmsNCTqvGSNyar1hdA58dKPRZjx6d6uemEagwU) does not match running node's ID (12vT7aqxk79EJXG35UTVYGNcqVVBKE2Q3U3uENi1beuy1Frytvg)
I also saw in another post that this maybe shows my node is disqualified (which i hope not) and i really cant hurt my cpu anymore for more new identities. It seems like that if i create an identity and then go offline for a day i get disqualified?? Hope you can fix this soon thanks
Now i also tried to delete the data as said in the other topic and my logs looks like this :
2021-05-04T10:43:50.999Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Error": "contact: failed to dial storage node (ID: 12vT7aqxk79EJXG35UTVYGNcqVVBKE2Q3U3uENi1beuy1Frytvg) at address aroulisstorj.ddns.net:28967 using QUIC: rpc: quic error: Timeout: No recent network activity"}
The port is shown as open but still :
-Bandwidth: N/A
-Dashboard only showed blank in the 127.0.0.1:14002 and is not accessible from my domain name or even local network on the specified port although apache server in port 80 is running just fine.
-Also: when visiting my domain name for a reason this showmy router login page i don’t know why is this happening.
I gave you all the details plz help me those normal checks are not the problem
update****
This is my dashboard in the command line which still doesn’t open in the device at 127.0.0.1:14002 or from local network or from domain
Storage Node Dashboard ( Node Version: v1.28.2 )
ID ###########################################
Status ONLINE
Uptime 5h10m43s
Bandwidth N/A 439.77 MB 2.96 MB 436.81 MB (since May 1)
Disk 3.59 TB 436.71 MB
Internal 127.0.0.1:7778 #none of those works
External ********************.net:28967
hello @peem , yes i do but i am connecting through ssh and i just use wget and the copy paste index.html in my local computer. For a reason i cant use my mouse when i have a hard drive connecter so cant use gui too…
Do you think if i open a browser in the node it will change things? Will it return something different than wget???
The bandwidth n/a is normal. There was a setting in the past where you could specify your monthly bandwidth. This setting has been deprecated since. It’s now required that you have unlimited bandwidth.
