I kinda agree on what you’re calculating. Having more small drives will cost more in the long run.
from my initial research, external 2.5" draws only around 2W but I never test it myself
but still your point is valid and it may be best to invest ‘more’ at the beginning and save elec cost later on
it depends on how cheap you can get the 4TB drive. sometimes you can get a huge bargain for it so let’s say you save elec XX EUR per year but it will take Y years to get that cheaper elec cost back. sometimes worth sometimes not. simple CAPEX vs OPEX
I have seen a trend though in past few months or even year that HD is getting cheaper. like more 20-30% cheaper than 2-3 years ago. I were buying something like 25-30 EUR per TB for 4TB, while the >4TB is exponentially more expensive. tech is better nowsadays
I really like the Western Digital Data center drives such as HC530, these are large capacity, >14 GB, low energy and long life. I have bought them in the past for $200-250 each on ebay new. For me reliability is the main factor.
The hard disk drive (HDD) is a non-volatile hardware device that works as the main storage in computers. It stores an operating system, software programs, and other files.
Hard drives are found on several devices. These include desktop computers, consumer electronics, mobile devices, and enterprise storage arrays in data centers, servers, and more. Its ability to work with a wide range of devices makes it a very versatile device.
Serial Attached SCSI (SAS)
These drive types use a small system interface to connect to the computer. They are faster and more reliable options. They are ideal for daily operations with better flexibility across different arrays. SAS drives are most commonly employed in servers, business computer systems, and best hard disk drive (HDD) for data centers.
Recently I got an hard drive, sharing its specs from the source I got this hard disk drive, but it is not a purchase recommendations.
HP 1TB 7.2K RPM Form Factor 3.5 Inches Hot Swap SAS Hard Drive in Tray.
General Information
Manufacturer : Hewlett Packard (HP)
Manufacturer Part Number : 537786-001
Manufacturer Website Address : HP official SiteHP 1TB 7.2K RPM Form Factor 3.5 Inches Hot Swap SAS Hard Drive in Tray.
Brand Name : HP
Product Name : SAS 300 Internal Hard Drive
Product Type : Hard Drive
Technical Information
Storage Capacity : 1 TB
Maximum External Data Transfer Rate : 300 MBPS
Rotational Speed : 7200 Rpm
Hard Drive Interface : 2 X SAS 300 Serial Attached SCSI
