I am having the same error
When using the tail command it says
''bin/sh: can’t open ‘entrypoint’: permission denied"
Please, show your docker run
command, you can remove the personal information from it. Use the code block section to post your command: use three ``` before the command at the first line and three after command at the last line
Also, please, post result of the command
docker info
sudo docker info
[sudo] password for tauke:
Containers: 2
Running: 2
Paused: 0
Stopped: 0
Images: 2
Server Version: 18.09.9
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: bridge host macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 894b81a4b802e4eb2a91d1ce216b8817763c29fb
runc version: N/A
init version: fec3683
Security Options:
apparmor
seccomp
Profile: default
Kernel Version: 5.4.0-33-generic
Operating System: Ubuntu Core 16
OSType: linux
Architecture: x86_64
CPUs: 2
Total Memory: 3.044GiB
Docker Root Dir: /var/snap/docker/common/var-lib-docker
Debug Mode (client): false
Debug Mode (server): false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
WARNING: No swap limit support
