docker logs storagenode | grep retain
2024-07-19T12:12:58Z INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 1975606, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 8720564, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "71h3m40.840352135s", "Retain Status": "enabled"}
ls /trash/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa
2024-07-13 2024-07-16
ls /trash/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa/2024-07-16/ | wc -l
1024
Files present in all subfolders. But Bloom filter still there, even 2 of them:
ls config/retain/
pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa-1720807199998472000
pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa-1720979999999803000
For me - yes. I believe, they are still processed, if we consider the limit to process a one BF until it’s finished. Because my nodes doesn’t have old BF files after they are processed. However, they are not restarted so often.
However, I insist that you need to join a
Your nodes are unique, they discovers so many issues, that it should help to improve the process.
