Buckets vs Folders
Is there anything that would drive me to having multiple folders within a bucket, or multiple buckets with a single folder?
We will be storing a range of data types, but all will synced to our StorJ project via the one system/source, which can use both buckets or folders.
What should be considered when making the decision?
Use paths (folders) as buckets are limited to 100 per project and you will likely hit that limit. If you need more buckets than 100 we can increase the limit but the answer is to use paths.
