I had always thought that the held amount structure start when you join the network (it also suggests this way in the docs) but now i have noticed that when i navigate to payout-information and select the new europe-north-1 satelite that the bar is showing 75% held back, but on the others it shows 50%:
The question is: if I start with 550gb and then during month 7-9 I decide to increase storage size … will I still keep 100% of the revenue generated by the new added capacity?
held amount only related with node age, not data age or storage age. you can put 550gb and after year add 10tb, new added space will not have held ammount at all if you add it after 9 months
