I complete the successfully Graceful exit from all satellite except from us2.tardigrade.io, my node has been running for 2 years, then when I look on dashboard payout information page on payout history all node are marked as Graceful exit complete but this satellite is missing form all previous and actual month:
Your node needs to be older than 6 months on a satellite to be allowed to do GE. us2 just joined very recently. besides, us2 has only 24MB of data as you posted and maybe $0.01 held at most.
The files on the disk should get removed eventually I think. Might take some time after a GE. but if you GEed on all satellites, you are going to delete everything anyway right?
You’re going to get the held amount for every satellite that successfully completed the graceful exit independently. So there is no need to worry about us2. You don’t need to exit that one. There wouldn’t be any held amount to give you for that one anyway.
