My isp uses CGNAT, so I can’t do port forwarding. But with NGROK or portmap I can do run a react js server on port 3000(http). So how can I do it with TCP?
Hello @jaykpatel304,
You have a few options:
- switch the ISP;
- use a VPN with port forwarding, such as PIA, portmap.io, purevpn, ngrok, etc
Yes i tried ngrok but i dont know which port to set. I Should assign port 4001 on the storj gui with host name that gave me? or i should use port that ngrok gave me?
Update:
I tried the hostname and port which ngrok gave me that I used in step 4(port number with reachable checked) and step 5 (hostname). After creating the port number color is turn into the green but it shows connecting continuously.
If you tried to setup a v2, then stop here, the v2 is deprecated and almost not used, your new v2 nodes will be empty anyway.
Please, subscribe to the waitlist v3 instead: https://storj.io/sign-up-node-operator/
