You can use this guide to access your dashboard remotely: How to remote access the web dashboard - Storj Node Operator Docs
Or use [Tech Preview] Multinode Dashboard Binaries
Simply put:
For example:
That is what i do…
tried all of them https http , without anything.
To be able to access your dashboard from a different device in your local network you should use either How to remote access the web dashboard - Storj Docs or use option
in your docker run command instead of
-p 127.0.0.1:14002:14002
You need also allow connections to 14002/tcp port in your firewall on your NAS.
Please do not publish this port in your router, otherwise anybody in the internet will have an unprotected access to your dashboard and storagenode’s API.
