Can't get rclone to work
# rclone config
No remotes found, make a new one?
n) New remote
s) Set configuration password
q) Quit config
n/s/q> n
Enter name for new remote.
name> storj-fu
Option Storage.
Type of storage to configure.
Choose a number from below, or type in your own value.
[snip]
Storage> s3
Option provider.
Choose your S3 provider.
Press Enter to leave empty.
[snip]
provider> Storj
Option env_auth.
Get AWS credentials from runtime (environment variables or EC2/ECS meta data if no env vars).
Only applies if access_key_id and secret_access_key is blank.
Choose a number from below, or type in your own boolean value (true or false).
Press Enter for the default (false).
 1 / Enter AWS credentials in the next step.
   \ (false)
 2 / Get AWS credentials from the environment (env vars or IAM).
   \ (true)
env_auth> 1
Option access_key_id.
AWS Access Key ID.
Leave blank for anonymous access or runtime credentials.
Enter a value. Press Enter to leave empty.
access_key_id> jvzohkaclwulrmq6irokuu7vp7ya
Option secret_access_key.
AWS Secret Access Key (password).
secret_access_key> [redacted]
Option endpoint.
Endpoint for Storj Gateway.
 1 / Global Hosted Gateway
   \ (gateway.storjshare.io)
endpoint> 1
Edit advanced config?
y) Yes
n) No (default)
y/n> n
Configuration complete.
The access token and secret are the same as I’m using for Mastodon. Now when I run rclone copy test storj-fu:test, I get:
2023/02/06 21:43:52 ERROR : Attempt 1/3 failed with 1 errors and: Forbidden: Forbidden
        status code: 403, request id: 17415A4F41D8CC94, host id:
2023/02/06 21:43:52 ERROR : Attempt 2/3 failed with 1 errors and: Forbidden: Forbidden
        status code: 403, request id: 17415A4F464A08A4, host id:
2023/02/06 21:43:53 ERROR : Attempt 3/3 failed with 1 errors and: Forbidden: Forbidden
        status code: 403, request id: 17415A4F4A629FF3, host id:
2023/02/06 21:43:53 Failed to copy: Forbidden: Forbidden
What should I do?
What is likely happening is your S3 credentials were restricted to a certain bucket, so it doesn’t have permission to upload to the bucket you’ve specified.
What you can do is create new S3 credentials that includes your test bucket or have the access be for “All”
But I can list files just fine with rclone ls storj-fu:. And the key ID and secret is the same as I’m using for Mastodon.
The bucket name follows the : so it’s trying to upload to a bucket named test which either doesn’t exist or it doesn’t have permission to do so.
I think your bucket name was freakuniversity from your other post, so you’ll likely need to do something like rclone copy test storj-fu:freakuniversity/test
