Changed IP address | Node does not start anymore
Hello,
Today my ISP had issue and for almost 4 hrs I was offline. When internet came back, my IP had changed. First time in 12 years, even though I do not have a fixed one.
Now, I have changed the IP address in the configuration file, and since then the node does not start anymore. It tries and then stops.
Any ideas on how to solve that?
I am running one node on windows with windows installation and one node on a Synology NAS with docker. Both behave the same way.
Thanks.
Hello!
It’d probably be helpful to have a look at your logs: could you post what seems to be relevant here?
See:
Maybe your ISP put you behind CGNAT. Does the IP in your router match the IP you get at whatsmyip.org?
I believe I have found the issue, I forgot to change one object in the firewall, which still had the old IP address. Once I managed to update that, the Windows node started to work again like a charm, while in order to start the Synology Node I had to stop, remove the node and then use the RUN command with the new IP address. Everything seems to work now.
By consulting the logs of the docker node I have noticed the following lines which I do not like:
2023-06-01T21:40:03.510Z	INFO	Configuration loaded	{"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "server.address"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "operator.email"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "server.private-address"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "contact.external-address"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "operator.wallet-features"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "operator.wallet"}
2023-06-01T21:40:03.510Z	INFO	Invalid configuration file value for key	{"Process": "storagenode-updater", "Key": "log.stack"}
Why is it complaining? What’s wrong?
Thanks.
That’s what DDNS is for.
nothing
