Go checkout the new storage node dashboard ![]()
The current dashboard script looks the same. How do you launch the new dashboard?
http://127.0.0.1:14002/
New Dashboard, launch in browser
I feel like this time I have to write a bit more about the changes.
Audit failures:
We believe that we have identified the root cause. I can’t go into the details as long as the issues is not fixed. This release contains part 1 of the fix and as soon as part 1 is working we can go on and deploy part 2. If we are lucky that might be possible today. In this special case I don’t want to deploy part 2 on a Friday and I am not sure if we will have time for it around the town hall next week. I will try my best.
Kademlia removal:
You can read the full story here: Design Draft: Removing Kademlia
As a side effect you might see that the last_contact value on the CLI dashboard is not updated frequently. Especially on unvetted nodes.
Vetting process:
Audit 2.0 is now live. Again you can read the full story here: Design Draft: Auditing 2.0
My expectation is that you don’t get any audits for the next 24 hours. (While I write that down I notice that I should create a bug for that. The first iteration should start on startup.) Anyway. Every 24h the satellite will go through all pointers and for each storage node select 3 of them. If you have only 3 pieces you still have a high chance to get an audit. The 3 slots are not fixed and we might change that value any time.
Storage node dashboard:
Just webbrowser http://127.0.0.1:14002 don’t forget to add -p 127.0.0.1:14002:14002 to your docker run command or the port will be closed. I will open a new thread for the dashboard and you can write down your feedback there.
If you are not running docker than I am sorry to say that we don’t support that. Take a look at the changelog and you should find the steps you need to execute
One note for your dashboard page.
This will only allow connections from the local machine. If you don’t have a gui on the local machine with a browser, you’ll need to use extended properties here to open it to your LAN, or another subnet.
Wide open is: Just make sure you have some other firewall/VLAN microsegmenting, and/or most importantly, blocking that from your WAN / ISP.
-p 14002:14002
Since last update last contact can go Up to 2 minutes but everything looks ok in logs.
@John.A That’s expected after the (partial) Kademlia removal
@BrightSilence I Read that and forgot all about it when i looked at the dashboard. Thanks.
Mine is very similar on 118U, except that i went negative altogether.
looks like someone will be paying back to 118U this month
I still cant wrap my head around the total numbers here:
143TB / 19 days / 24h is 0,3TB but on the cli dashboard i have used 1.8TB
Yes. Sorry I have missed to post that information in both threads. Here is the explanation:
Awesome update, thanks!
Btw, will storage nodes be automatically unpaused for this update?
I noticed my node is still paused for 1 satellite.
Not automatically. You have to contact the support.
