bota87
February 19, 2020, 9:02pm
61
Automatic update completed but now I notice some of this error in the log, all from the same satellite
2020-02-19T20:55:04.897Z ERROR piecestore delete failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "PBDSJXA3QJ2T5HUPGXA4LJXZYAG2FA5UXOL3YCAKMXA5JL5XCSGQ", "error": "pieces error: context canceled; v0pieceinfodb error: context canceled", "errorVerbose": "pieces error: context canceled; v0pieceinfodb error: context canceled\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:289\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).DeletePieces:188\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func5:1100\n\tstorj.io/drpc/drpcserver.(*Server).doHandle:199\n\tstorj.io/drpc/drpcserver.(*Server).HandleRPC:173\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:124\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:161\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
bota87:
context canceled
Your node failed to delete a file before the timeout hence its a delete failed. Its perfectly fine though. Garbage collector will pick them up eventually.
My windows node has still not auto-updated, should I be manually updating it or just leave the updater to do it for me?
Alexey
February 19, 2020, 10:33pm
64
Please, give me result of the command (Powershell):
Get-Service storagenode*
Alexey:
Status Name DisplayName
Running storagenode Storj V3 Storage Node
Running storagenode-upd⌠Storj V3 Storage Node Updater
Alexey
February 19, 2020, 10:52pm
66
Then it should update itself. Please, do not update it manually
It doesnât, in fact itâs worse. My Pi node had almost 95% upload failure rate (reported) in successrate, but I can still see in my logs that âfailed to uploadâ pieces were then deleted less than a minute later.
The 100% cursor was deployed yesterday.
The setting to what % of nodes would get the update on the next version check. Everyone should get the new version on the next update now.
