Changelog v0.35.3
I would like to pay attention, that update to version 0.35.3 is softer than all previous after a node is started is not produce a lot of load (IO disk operations) like previous upgrades, I don’t know what changed, but it really nice change!
is this my problem docker Mac OS H Sierra Screen Shot 2020-03-30 at 07.52.11
new version still show misalignment
Which problem do you mean? The problem that you didn’t read the changelog especially the part about removing the bandwidth limits?
Isn’t N/A supposed to be under “Available”? The values are shifted.
My Linux node dashboard is the same - the values are shifted.
Hello!
Thank you for mentioning. I’ve transferred this issue to devs team so it’s going to be fixed soon
Looks fine for me image
For me misalignment only happens when I set color: true in config.yaml.
Try to set it to false
this issue has been fixed so you should see the colored dashboard display properly without the shifted numbers starting with the next release (v1.3)
