Changelog v1.14.4
I even gave the exact behavior in a channel. We select Everything that’s at max 1 minor version behind the satellite.
Eg. If the satellite is on v1.14.X, everything running on v1.13.X and up gets ingress.
The flag that we use for that is —overlay.node.minimum-version
I am really not sure why you keep on insisting us doing ninja tricks to make storagenodes unhappy. I tried my best to explain why this secondary soft limit exists and how a bad updater in v1.12.3 has caused the problem of not getting ingress.
Doing manual updates whenever you feel like it is simply discouraged and automatic updates are the recommended way for your node to stay healthy. If you can not accept this fact, then this is still no reason to keep blaming others.
