Changelog v1.40.4
For Storage Nodes
Audit Penalties for Repair Failures
The audit job is checking a random 1 KB stripe out of a piece. The repair job is checking the entire piece. It is possible that the repair job detects a corrupted piece while the audit job believes it is all fine. Another possible problem is that storage nodes could pass audits but deny repair downloads to maximize profit. We have decided to enable the repair job to update audit reputation. This works in both direction. A successful repair download will increase the audit reputation.
For Customers
Server Side Move
The new uplink binary has now a server side move command. You can rename a file or move it to a different folder or even bucket. Renaming a folder is not possible at the moment. We might implement that in a future release.
Note: We haven’t solved the build process for OSX. If you need server side move on OSX please contact us.
It would be possible but it would also open a loop hole. Just delete the oldest pieces and you can free up space without getting disqualified.
The audit job will tolerate a few bit flips. That shouldn’t get any node disqualified.
No problem. Thank you for your idea.
nice to see that’s finally fixed, was kinda wondering where it was at lol.
still waiting for deleted storagenode GB on the main graph on the dashboard.
