If a node with established reputation were to be moved to a different physical location (different IP) but behind a dynamic address, would it be disqualified? For instance, if you had to move to a new house with a new, equivalent connection.
The node itself has proven to be reputable, but would just be moved to a different connection.
Please follow the migration instructions so you will make sure to edit the IP address/DDNS and port forwarding used with your new ISP at the new location.
Just setup a new node “GUI”, but at the part of the setup where it asks you where you want to store the storj files, point it to all the files from your old node. And the migration settings are not out dated… Yet.
