Hello,
Incoming traffiv on one of my node become half of the normal. I have seen command which can check quantity of nodes under one subnet, but can’t find with search. Could you help with link?
Regards,
Alexander
Hello,
Regards,
Alexander
It’s not a command as such.
You can go to this link at StorjNet, input your IP address and it should tell you how many nodes are running on that /24 ![]()
You can also pull it from the StorjNet API if you want it on the CLI. Like substitute your IP onto the end of something like this:
wget -q --output-document - https://storjnet.info/api/neighbors/85.143.219.169
…and you should get a chunk of JSON with your peer count: similar to this:
{“ok”:true,“result”:{“count”:42}}
I stand humbly corrected ![]()
If you have jq installed, just pipe the result into it.
wget -q --output-document - https://storjnet.info/api/neighbors/85.143.219.169 | jq -r .result.count
Thanks to everybody! I did
