Hello,
Is there a problem for running a node on the disk that mine chia at the same time?
No. What problems are you anticipating?
Thank you for your reply.
I’m asking before I do transfer some Chia plots to my Storj node disk.
Storj is intended to make use of extra space you cannot use for anything else. So if you make use of the space for chia, and have some left over, you can allocate it for Storj.
