Hello guys, I am an three node operator for the last year and during this time I have migrated the nodes flawelesly from rpi to odroid.
My issue comes when my third node migration raises the following error for all the satellites:
connect: connection refused", “errorVerbose”: "ping satellite error: failed to dial storage node (ID: 19wbcWmRMSvxuihF14Mf3PAPUksTaVdwgFT6K4QN49tNG6Uyqa) at address XXX connect: connection refused
Searching throughout logs I found something strange
docker logs storagenode 2>&1 |grep server
2021-03-04T22:38:45.637Z INFO Public server started on [::]:7777
2021-03-04T22:38:45.637Z INFO Private server started on 127.0.0.1:7778
Remaining two nodes raise a different Public port server:
2021-03-03T22:02:06.525Z INFO Public server started on [::]:28967
2021-03-03T22:02:06.525Z INFO Private server started on 127.0.0.1:7778
2021-02-18T17:01:31.714Z INFO Public server started on [::]:28967
2021-02-18T17:01:31.714Z INFO Private server started on 127.0.0.1:7778
Based on that, I presume it is a matter with published port 7777 instead of 28967. I could change the port 2869 to 7777 and probably it would work but I do not understand why docker has decided by itself to move to 7777 port.
All three nodes are physical independent and do not share the same Internet connection.
Any help on this it would be appreciate.
