Corrupted badger databases prevent node from starting after a file check.
There is still non way to repair those, correct? Only solution is to delete and re-create?
Yep. They didn’t work on badger anymore when hashstore launched. The only work I see is done for the hashstore in the recent versions. Stop the node and delete the badger db. And activate startup piece scan, of course.
That’s what I have thought… ![]()
Can someone explain to me why badger is now no longer in production?
is hashstore the new?
what should be done in regards to that?
But why did it get corrupted? Unsafe shutdown? Don’t you use UPS?
Yes. Server stopped functioning properly.
Badger is still there and works and supported, but no extra development effort is being spent on it.
You can optionally migrate a node to new setups like the hashtable and memtable, which is where all the effort is going:
[Tech Preview] Hashstore backend for storage nodes - Product Discussions / STORJLINGS - Storj Community Forum (official)
Still considered preview mode. Personally I’ve stuck with the old setup since it’s been fine under relatively low loads of traffic. (+I use badger on three nodes that have really slow storage and it helps on them).
Thanks. I got badger on all my nodes, been running just fine. On many many 10’s for nodes on each machines
so won’t do hashstore right now.
