Every hour such a mistake. How to cure?
2019-12-14T06:57:58.779Z ERROR piecestore could not get hash and order limit {"error": "v0pieceinfodb error: sql: no rows in result set", "errorVerbose": "v0pieceinfodb error: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:132\n\tstorj.io/storj/storagenode/pieces.(*Store).GetV0PieceInfo:607\n\tstorj.io/storj/storagenode/pieces.(*Store).GetHashAndLimit:420\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:541\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:443\n\tstorj.io/storj/pkg/pb.DRPCPiecestoreDescription.Method.func2:993\n\tstorj.io/drpc/drpcserver.(*Server).doHandle:175\n\tstorj.io/drpc/drpcserver.(*Server).HandleRPC:153\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:114\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:147\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
Seems your database has been recreated at some point and doesn’t contain any data yet.
Did you lost it sometime ago?
I have 6 nodes now.
The bases on this node are original.
But on this same node, an error locking the database occurs
