I just created my node about a month ago. In this time I have had some disconnections. According to the image and the age of my node. Is it possible for the Storj audit to ban my node?
Hello @Richard1!
The uptime metrics you are shown above are from your node and Storj does not have any way to take down your node.
Audits are not affecting your node’s offering of service to the public world.
I would recommend checking your router logs, if your entire internet was down during those timeframes. Else you might want to check your Windows restarts (caused by updates, etc).
