When I run identity authorize storagenode <your STORJ token >
on my Synology NAS, it shows:
2022/10/24 23:29:20 proto: duplicate proto type registered: node.SigningRequest 2022/10/24 23:29:20 proto: duplicate proto type registered: node.SigningResponse 2022-10-24T23:29:20.443+0800 INFO Anonymized tracing enabled Error: rpc: tcp connector failed: rpc: dial tcp 103.56.16.112:8888: i/o timeout
I has DDNS for dymc ip. and I have closed firewall.
Hello @phoenix,
Something is blocking outgoing connections from your NAS. Please check firewall on your NAS and router.
But I have tried to telnet 103.56.16.112 8888 on google cloud’s Virtual machine instances, also can’t work.
how can I check the tcp connector working?
With identity authorize storagenode your-token-here
command.
this command run log above. will occur rpc error
You may copy your identity to another device and try to authorize it there, then move signed identity back to Synology. However, you need to fix the underlaying problem with the network - you should not block outgoing connections.
May be your network interface on Synology have a wrong IP (for example - duplicated), or improperly configured.
I have solved it. Because my NAS can’t connect to “certs.alpha.storj.io”. I use a network- proxy to run identity authorize storagenode
