Create an Identity
Greetings to all, I am Italian and I struggle with English … I tried to create my identity several times but I never managed to get the folder with 6, mine always contains 4 files, what can I do Now ??
Hello @gigetto65,
What the output of the authorization command?
C:\Users\LENOVO X201>identity_windows_amd64.exe create storagenode
2019-07-23T11:19:04.535+0200 ERROR Failed to do periodic version check: %!(EXTRA *url.Error=Get : unsupported protocol scheme “”)
Generating key with a minimum a difficulty of 30…
Generated 5346946 keys; best difficulty so far: 30
Found a key with difficulty 30!
Unsigned identity is located in “C:\Users\LENOVO X201\AppData\Roaming\Storj\Identity\storagenode”
Please move CA key to secure storage - it is only needed for identity management!
C:\Users\LENOVO X201\AppData\Roaming\Storj\Identity\storagenode\ca.key
Please, authorize it with an authorization token from the invitation email and post result (the token itself you can hide): https://documentation.storj.io/setup/identity#sign-the-identity
I’m experiencing what appears to be a similar problem with signing the identity but using a linux binary:
$ ./identity_linux_amd64 authorize storagenode <my token was here>
2019-07-24T19:46:47.101+0200	ERROR	Failed to do periodic version check: Get : unsupported protocol scheme ""
The version error is not a problem, did it show anything else in the response?
nope and it didn’t sign the identity either
don’t know if this will help:
futex(0xc000066848, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0xc000066bc8, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0xc000066f48, FUTEX_WAKE_PRIVATE, 1) = 1
clock_gettime(CLOCK_MONOTONIC_RAW, {tv_sec=204, tv_nsec=573341558}) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {tv_sec=204, tv_nsec=573920436}) = 0
newfstatat(AT_FDCWD, "<my_home_dir>/.local/share/storj/identity/config.yaml", 0xc0002046b8, 0) = -1 ENOENT (No such file or directory)
socket(AF_INET, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, IPPROTO_IP) = 3
setsockopt(3, SOL_SOCKET, SO_BROADCAST, [1], 4) = 0
openat(AT_FDCWD, "/proc/sys/net/core/somaxconn", O_RDONLY|O_CLOEXEC) = 5
epoll_ctl(4, EPOLL_CTL_ADD, 5, {EPOLLIN|EPOLLOUT|EPOLLRDHUP|EPOLLET, {u32=2210336424, u64=140198532812456}}) = 0
fcntl(5, F_GETFL)                       = 0x8000 (flags O_RDONLY|O_LARGEFILE)
fcntl(5, F_SETFL, O_RDONLY|O_NONBLOCK|O_LARGEFILE) = 0
read(5, "128\n", 65536)                 = 4
read(5, "", 65532)                      = 0
epoll_ctl(4, EPOLL_CTL_DEL, 5, 0xc0001d7054) = 0
close(5)                                = 0
setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
bind(3, {sa_family=AF_INET, sin_port=htons(0), sin_addr=inet_addr("127.0.0.1")}, 16) = 0
listen(3, 128)                          = 0
epoll_ctl(4, EPOLL_CTL_ADD, 3, {EPOLLIN|EPOLLOUT|EPOLLRDHUP|EPOLLET, {u32=2210336424, u64=140198532812456}}) = 0
getsockname(3, {sa_family=AF_INET, sin_port=htons(41513), sin_addr=inet_addr("127.0.0.1")}, [112->16]) = 0
rt_sigprocmask(SIG_SETMASK, ~[HUP INT QUIT ILL TRAP ABRT BUS FPE SEGV TERM STKFLT CHLD PROF SYS RTMIN RT_1], NULL, 8) = 0
futex(0x16506e8, FUTEX_WAIT_PRIVATE, 0, NULL) = 0
futex(0xc000067648, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x16506e8, FUTEX_WAIT_PRIVATE, 0, NULL2019-07-25T00:16:21.962+0200	ERROR	Failed to do periodic version check: Get : unsupported protocol scheme ""
+++ exited with 1 +++
where can I find older versions of the binary? is there anyway to browse the artifacts you publish on https://storj-v3-alpha-builds.storage.googleapis.com/ ?
let me know if you need any more info
We updated documentation, please, check the link above
it worked, thanks @Alexey!
Hi everyone, I was wrong of course … now everything is ok. I hope shortly to start my node with 2 disks for a total of 2TB
