Are satellites completely isolated from each other?
If I create projects, keys and buckets on us-central-1, can I somehow access my bucket from europe-west-1 ? Or can my bucket and objects only be accessed via us-central-1 satellite ?
Hi @ap0gee, You are correct, the satellites are isolated from one another and you won’t be able to access buckets and objects from a different satellite. However, you can share the buckets or objects via uplink and, with the correct permissions, modify them without needing to know which satellite they’re on. Hope that helps.
