You should start sending bloom filters for other satellites too, because the trash is empty for them and I see the discrepancy between sats average and used space increasing with 100GB/day.
Anything else…: garbage folder is empty, temp has no old pieces, trash folder looks good, no oldies or recursives.
I didn’t compared the dashboard with trash size on disk, to confirm or infirm what other report about trash not being updated in database.
We are sending, as far as I know.
UPDATE:
We are generating 10Mb bloom filters, but we didn’t send out any new one during the weekend.
We noticed a problem: some clients reported that pieces are trashed, which shouldn’t be.
This problem looks to be related to one storagenode only: we continue to send out 10Mb files.
Weekend is spent to generate new US BFs, which is close to the end (2.7 B segments out of ~3+ B), they will be sent out very soon (will be started within 1 days)
We are discussing the following changes for the following weeks:
- Sending out only 10+Mb bloom filters. No more 4Mb any more. Majority of the nodes are already updated to 1.101+ version. We don’t need to wait more.
- Gradually increase max 10Mb limit to 15-18Mb.
- BF generator will always use the free capacity to generate new BFs instead of waiting for the next scheduled period. (which means 4-5 days BF period instead of 7 days)
Wow! That’s not good! Can you tell us more?
If it’s only one SN, the operator should be notified and get some explanations from him. Maybe he modified the storagenode software or has some strage settings or a virus.
Is there a way to verify if all other nodes trashed the correct pieces?
We should be realy sure before moving forward, that we are not all affected.
This is exactely why we should not delete the trash manualy. Let the node software do it’s thing.
We have an alert for that. The way it works is that the storage node treats pieces in the trash folder different. If an audit comes in the node will restore the piece from trash and respond to the audit but with one additional flag. It will signal the satellite that something is wrong here and the satellite will inform us that one of the nodes has returned that alert flag.
Yes, we are working on it, and doing very similar things what you suggested. And that’s why we stopped sending out BFs for the weekend, just to be extra cautious.
Audit continuously monitor the network, but in addition that, storagenode can signal to the client if the requested pieces were served from the trash instead of the normal directory. This is where we got the alerts (clients on gateway-mt reported the issue)
That’s happened for one single storage node, and only for a few dozens of requests out of thousands. The affected storagenode was not part of the 10Mb experiments (when I sent out BFs manually).
Still we are investigating the issue (and keeping our eyes on all metrics). There can be other reasons for this as well, but some of them should affect multiple storagenodes (too early TTL deletion? time skew? or just using some specific cheating strategy…)
So no time to panic, and strongly agree with your call to be careful…
It seems that 99.5% of the data on my node is uncollected garbage (this has grew exponentially in the last 24 hours, from 25% to nearly 100%). Is this part of the same problem? Anything I can do to avoid the issue moving forward?
Let it be. When you gatter 10+ TB of data, you can keep an eye on numbers. In the GB range just ignore it. It’s normal.
same for me with a big node of 14tb. seems a problem with earnings script (i use 13.4.0)
Hey @Seb and @wildwaffle please see the below post.
This is a separate issue. This graph shows info from the satellites: they sends reports to the nodes regularly, but if the tally took more time than expected, your node will not receive a report in time, thus there will be a gap.
Usually it is closed in the next few days, when your node will receive missing reports.
Please see this comment: Announcement: major storage node release (potential config changes needed!) - #70 by pdeline06
2024-05-06T14:54:33Z INFO lazyfilewalker.gc-filewalker subprocess finished successfully {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-06T14:54:33Z INFO retain Moved pieces to trash during retain {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 24352, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 1363663, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "13m22.8536556s", "Retain Status": "enabled"}
US1 BF generation is finished during the night. Satellite is just sending out BFs.
I believe EU1/AP1/SLC were sent earlier during the week…
We are bumping size to use 12Mb as the max…
BF generation will be more frequent (it’s an earlier plan, but didn’t work well. Now it should).
Just thinking aloud: Would it help if more frequent generation of bloom filters was limited only to nodes crossing the former maximum of 4 MB bloom filters? This would reduce the load on smaller nodes (which don’t need more frequent bloom filters), while potentially reducing amount of compute necessary to generate these bloom filters satellite-side (maybe making them more frequent for larger nodes).
It will stop when hitting zero used space. ![]()
