2023-01-09T12:26:55.121751439Z 2023-01-09T12:26:55.121Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"Process": "storagenode"}
2023-01-09T12:26:55.121897348Z 2023-01-09T12:26:55.121Z INFO Node 1kBFsLwgWwLvv49reEcYtDX47xfz75m9jku74UsAGRqRKXBvUE started {"Process": "storagenode"}
2023-01-09T12:26:55.122015454Z 2023-01-09T12:26:55.121Z INFO Public server started on [::]:28967 {"Process": "storagenode"}
2023-01-09T12:26:55.122024394Z 2023-01-09T12:26:55.121Z INFO Private server started on 127.0.0.1:7778 {"Process": "storagenode"}
2023-01-09T12:26:55.122335275Z 2023-01-09T12:26:55.122Z INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details. {"Process": "storagenode"}
2023-01-09T12:26:55.956302777Z 2023-01-09T12:26:55.955Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "3h57m34.475441515s"}
2023-01-09T12:26:55.956326797Z 2023-01-09T12:26:55.956Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T13:22:27.427621143Z 2023-01-09T13:22:27.427Z INFO Configuration loaded {"Process": "storagenode", "Location": "/root/.local/share/storj/storagenode/config.yaml"}
2023-01-09T13:22:27.427716454Z 2023-01-09T13:22:27.427Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2023-01-09T13:22:27.626861241Z 2023-01-09T13:22:27.626Z INFO Operator email {"Process": "storagenode", "Address": "sylvaincrypto@protonmail.com"}
2023-01-09T13:22:27.626916572Z 2023-01-09T13:22:27.626Z INFO Operator wallet {"Process": "storagenode", "Address": "0x671e3e50682234909a3958ac00a3fa0f55752283"}
2023-01-09T13:22:29.042022140Z 2023-01-09T13:22:29.041Z INFO Telemetry enabled {"Process": "storagenode", "instance ID": "1kBFsLwgWwLvv49reEcYtDX47xfz75m9jku74UsAGRqRKXBvUE"}
2023-01-09T13:22:29.259546447Z 2023-01-09T13:22:29.259Z INFO db.migration Database Version {"Process": "storagenode", "version": 54}
2023-01-09T13:22:29.969761090Z 2023-01-09T13:22:29.969Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"Process": "storagenode"}
2023-01-09T13:22:30.952882676Z 2023-01-09T13:22:30.952Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"Process": "storagenode"}
2023-01-09T13:22:30.952993298Z 2023-01-09T13:22:30.952Z INFO Node 1kBFsLwgWwLvv49reEcYtDX47xfz75m9jku74UsAGRqRKXBvUE started {"Process": "storagenode"}
2023-01-09T13:22:30.953002271Z 2023-01-09T13:22:30.952Z INFO Public server started on [::]:28967 {"Process": "storagenode"}
2023-01-09T13:22:30.953006459Z 2023-01-09T13:22:30.952Z INFO Private server started on 127.0.0.1:7778 {"Process": "storagenode"}
2023-01-09T13:22:30.953117154Z 2023-01-09T13:22:30.953Z INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details. {"Process": "storagenode"}
2023-01-09T13:22:31.450713920Z 2023-01-09T13:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T13:22:31.479848164Z 2023-01-09T13:22:31.450Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "7h6m4.669836467s"}
2023-01-09T14:22:31.451624454Z 2023-01-09T14:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T15:22:31.455021510Z 2023-01-09T15:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T16:22:31.451124986Z 2023-01-09T16:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T17:22:31.451257166Z 2023-01-09T17:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T18:22:31.451152541Z 2023-01-09T18:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T19:22:31.464234564Z 2023-01-09T19:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T20:22:31.453777169Z 2023-01-09T20:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T20:28:36.443649164Z 2023-01-09T20:28:36.443Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "5h49m28.18191304s"}
2023-01-09T21:22:31.450988679Z 2023-01-09T21:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T22:22:31.451539591Z 2023-01-09T22:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-09T22:24:41.704105298Z 2023-01-09T22:24:41.604Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2023-01-09T22:24:42.371032832Z 2023-01-09T22:24:42.370Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2023-01-09T22:24:43.041550456Z 2023-01-09T22:24:43.041Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2023-01-09T22:24:44.207808633Z 2023-01-09T22:24:44.207Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2023-01-09T22:24:44.327131172Z 2023-01-09T22:24:44.327Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2023-01-09T22:24:44.690992000Z 2023-01-09T22:24:44.690Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 178.194.92.72:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2023-01-09T23:22:31.451766414Z 2023-01-09T23:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T00:22:31.451679086Z 2023-01-10T00:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T01:22:31.451031474Z 2023-01-10T01:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T02:18:04.748937778Z 2023-01-10T02:18:04.748Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "2h55m35.529725227s"}
2023-01-10T02:22:31.451529325Z 2023-01-10T02:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T03:22:31.451195989Z 2023-01-10T03:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T04:22:31.450910342Z 2023-01-10T04:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T05:13:40.706657891Z 2023-01-10T05:13:40.706Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "6h29m10.496178214s"}
2023-01-10T05:22:31.453979959Z 2023-01-10T05:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T06:22:31.451746055Z 2023-01-10T06:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T07:22:31.450772253Z 2023-01-10T07:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T08:22:31.451528842Z 2023-01-10T08:22:31.451Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2023-01-10T09:22:31.451120957Z 2023-01-10T09:22:31.450Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
