Hi team,
1 week for this result, please help.
root@pyweb:/storj# docker exec -it storagenode /app/dashboard.sh
2022-04-08T20:30:29.522Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2022-04-08T20:30:29.524Z INFO Identity loaded. {“Node ID”: “1ZXc######################”}
Error: rpc: dial tcp 127.0.0.1:7778: connect: connection refused
What’s rpc : dial? I cannot see if all is good :’( no dashboard. I attempt the web API, i don’t now if my tunnel is good to join the port server with putty, the web page say “La connexion a échoué”
I just past my raspberry in 64 bits to use your software and the docker image V8, impossible with a version 7.
i think docker is OK
root@pyweb:/storj# docker ps -a
f2b024b04fcb storjlabs/watchtower “/watchtower storage…” 22 minutes ago Up 22 minutes watchtower
d4dea6881d0f storjlabs/storagenode:latest “/entrypoint” 22 minutes ago Up 4 seconds 127.0.0.1:14002->14002/tcp, 0.0.0.0:28967->28967/tcp, 0.0.0.0:28967->28967/udp, :::28967->28967/tcp, :::28967->28967/udp storagenode
the forward on my box is OK. And for the test i have no firewall active on the server.
How to see a dashboard to verify ?
If you want more log i can.
