I have found its not the first time this has happned to me on a Linux storj Docker setup and I am starting to think its a case of “problem exists between keybord and chair”
On my storj server I cannot get to the web GUI dashboard. I have read many forums and they all say navigate to your in my case its 192.168.0.40:14002.
My Docker setup is as follows:
-p 28969:28967
-p 127.0.0.1:14002:14002
-e WALLET=“0x138B29C26b84aCBf1529F0906E34757d8B1552c9”
-e EMAIL=“simon.**@gmail.com"
-e ADDRESS=".duckdns.org:28969”
-e STORAGE=“1.7TB”
–mount type=bind,source="/Drive1/identity/",destination=/app/identity
–mount type=bind,source="/Drive1/data/",destination=/app/config
Am I missing somehing? in Docker am i suposed to be installing anything additanal to help the web page be displayed?
This is on a clean Ubuntu server and I am not an advanced user of Linux but know how to break things will ( hope that makes sence )
Im having problems of this kind, i have two nodes on an ubuntu server
First node are working fine, second one is fresh new node, docker dashboard is working but web dashboard is not. Im using -p 14002:14002 for first node and -p 14003:14003 for second one
On the second node. The first port mentioned is the external port, the second is the port inside the container. I side the container the node will always use 14002 for the dashboard.
