You might be running out of space on your system disk, not your data disk. Docker can take up a lot of space after a while. You can try running docker system prune to clean up unused stuff.
i clean up all old containers with:
docker system prune --all --force --volumes
but still no space on /tmp/pty425872207
docker exec -it storagenode /app/dashboard.sh
failed to create runc console socket: mkdir /tmp/pty425872207: no space left on device: unknown
also cleaned the tmpfs.
still no dashboard.
do you have another idea? thanks
I try to get info at docker also …
I’m not sure at the moment whether that is trying to create the socket inside the docker container or outside, but could you paste the output of sudo sh -c 'cat /proc/mounts; df' | grep '/dev\b' ? That may reveal some clue in the volume mounting and usage details.
