On the dashboard page, does 100% status on Suspension, Audit, and Online mean 100% suspended across all satellites, failed all audits and have just been connected to the server?
100 % = all is good.
The lower the percentage the worse the situation. If your audit drops below 60 % for a satellite you get disqualified on that satellite.
No, 100% means everything OK.
I have another question: What do yellow exclamation mark icons mean beside each entry? I did move the node and therefore it was offline some hours.
Yellow exclamation mark = something’s not 100 % right, you should check what’s causing this
Red exclamation mark = the node’s been disqualified, it’s game over for this satellite
