I see that not all data was wiped after upgrade to v0.15.2
The garbage is persists on <storj_data_dir>/storage/tmp
for me it about 1050MB
My data did wipe, I only have 6.6Gig allocated, mostly from info.db. (I thought that said 6.6T earlier. I think it’s time for bed… )
Size/Used/Avail/Use%
Probably all tests are stopped for now, that’s why we do not get any data.
It wiped the data for me (took a couple of hours to do it though), just left the 5.8GB db file.
Could you please check it on your side?
It has 17 files, total 2.1MB
I can confirm this issue on both of my storage nodes.
We’ll roll out a migration which will remove tmp
directory.
There is a PR already sent for it https://github.com/storj/storj/pull/2582
Confirm too.
root@node:/home/StorjStore/storage/tmp# ls blob-018858431.partial blob-088048577.partial blob-182037527.partial blob-351749016.partial blob-623961691.partial blob-822719331.partial blob-028807561.partial blob-129220266.partial blob-215269002.partial blob-446031870.partial blob-679443814.partial blob-833343980.partial blob-045277951.partial blob-134160795.partial blob-245560551.partial blob-470833170.partial blob-697796681.partial blob-838369607.partial blob-051321477.partial blob-161140192.partial blob-274520461.partial blob-527196040.partial blob-769917946.partial blob-902493740.partial blob-083985409.partial blob-165529413.partial blob-326422113.partial blob-623376599.partial blob-812587796.partial blob-995820817.partial root@node:/home/StorjStore/storage/tmp# ls | wc -l 30
Mine is gone as well, 1.8TB. makes me sad
