Dcoker-compose ERROR
Hi! I’m new around here trying to play.
I am trying to count a node in CentOS 8 with docker and it gives me several problems. I would appreciate if you could give me a hand.
version: "3.8"
services:
  storagenode:
    restart: unless-stopped
    ports:
      - 28967:28967
      - 14002:14002
    environment:
      - WALLET=0xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
      - EMAIL=xxxxxxxxxxxxxx@xxxxxxxx
      - ADDRESS=myaddress.ddns.net:28967
      - STORAGE=1TB
    volumes:
      - type: bind
        source: /home/user/.local/share/storj/identity/storagenode
        target: /app/identity
      - type: bind
        source: /storj
        target: /app/config
On a less important note, if I put my noip address in “ADDRESS”, I get the following error when trying to start the docker.
Now, if I put my IP, it seems that advances something more (honestly, I do not explain because noip is taking my IP correctly …), however, comes out an error apparently with the satellite clock and more than investigate, I get nothing …
Any bright ideas to enlighten me?
I can not believe it … with the hours I spent looking for the problem and I have not found it… :man_facepalming:t2: :man_facepalming:t2: :man_facepalming:t2:
Thank you very much for your help.
with debian works well?
I’m using storj on Debian and it’s working like a charm :slight_smile:
no problems on ubuntu, so I guess debian should be fine too
Using Raspbian here… Works ok.
It counts as Debian too right? :slight_smile:
I want to cry…
after so many hours of effort, now I have installed debian and it has worked at first.
Thank you all very much for your help.
