Debug port metrics in graphical dashboard
Can someone crafty make some graphical dashboard with all the metrics available through the debug port? … maybe with explanations for each one?
Looking at those strings makes my dizzy.
I know there is Graphana/Prometeus, but is to complex and I don’t need the tracking part; I don’t want to install all kinds of services. Just a simple dashboard easy readable, instead of those strings of text. Thanks in advance!
I can add some to my audit soft, but i need info, what is what, there is several hundreds of things there in metrics
I imagine only AI could sort them out, by going through the entire source code, findind what is what and add some explanations to each. And then puting all together in a dashboard.
I’m using victoriametrics, it’s way simpler to set up than prometheus and grafana together. And it comes with a simple data browser, it’s enough for basic checks. And the right approach is just show what turned out to be useful in the past (like, checking on the forum maybe?), no point in displaying all of them.
You can use this one:
