Delete blobs of europe-north-1 and us2?
# ./storagenode exit-satellite --identity-dir ./identity
2023-08-05T14:33:39Z	INFO	Anonymized tracing enabled	{"process": "storagenode"}
2023-08-05T14:33:39Z	INFO	Identity loaded.	{"process": "storagenode", "Node ID": "17s41dsY7PsVGRgkdwYuxkfKyv5o3ZDbu88UzfaihL1sE6S3Bm"}
By starting a graceful exit from a satellite, you will no longer receive new uploads from that satellite.
This action can not be undone.
Are you sure you want to continue? [y/n]
 :y
Domain Name                        Node ID                                              Space Used
us2.storj.io:7777                  12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo   3.97 GB
saltlake.tardigrade.io:7777        1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE   0.72 TB
ap1.storj.io:7777                  121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6  561.02 GB
us1.storj.io:7777                  12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S  2.26 TB
eu1.storj.io:7777                  12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs  2.69 TB
europe-north-1.tardigrade.io:7777  12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB  111.64 GB
Please enter a space delimited list of satellite domain names you would like to gracefully exit. Press enter to continue:
^C2023-08-05T14:33:51Z	INFO	Got a signal from the OS: "interrupt"	{"process": "storagenode"}
Is it safe to delete manually?
There will be no solution?
Can I remove these blobs?
US2 - arej6usf33ki2kukzd5v6xgry2tdr56g45pp3aao6llsaaaaaaaa
North - 6r2fgwqz3manwt4aogq343bfkh2n5vvg4ohqqgggrrunaaaaaaaa
Stefan? - abforhuxbzyd35blusvrifvdwmfx4hmocsva4vmpp3rgqaaaaaaa
I’ve got this same issue. Many of my nodes share several TB worth of data, stuck in old blobs folders. On the dashboard Suspension & Audit section, I see just the four now primary satellites, but still have all 6 Blobs folders.
Is the method below still the preferred way of cleaning up, @clement?
Yes, you may use this instruction to delete this data, just need to explicitly list satellites in the forget-satellite command
or explicitly add them to the untrusted list
and use the flag
To delete also blobs data you need to use the flag
Thank you for the clarification - this worked flawlessly for me :slight_smile:
