Can I delete a bucket from my account to reclaim the space if I have lost the encryption key? Wasn’t easily able to find the answer in the docs. Thanks!
Hello @TtheBC01 ,
@nerdatwork the rclone will not allow you to delete non-empty buckets too, and since the encryption key is lost, this bucket will looks like empty, but it’s not true - the current encryption key just unable to decrypt a content.
The working solution would be only to use uplink CLI.
To list buckets:
uplink ls
To remove a bucket even if you lost an encryption key:
uplink rb --force sj://bucket-to-remove
Thank you @Alexey, I will try this and mark as solution if I’m successful.
Finally got a chance to try this. Creating a temporary access grant with delete permissions and importing into uplink CLI worked great. Thanks @Alexey!
